Beiträge von Petsku
    I´m sorry, that i have not written, how light switch replace finally working. The reason is: i don´t know... Soon after light-problem, our Twingo began to keep strange noise from the "engine room" starting from cold. Our dealer doubted, that noise sounds kind of clutch would have been somekind damaged.
    My wife had enough. (Whole motor replaced earlier in the autumn, reason was disputable oil circulation problem). Too many problems almost new car. My wife was already changing car brand, but our Renault-dealer talked my wife about around. Besides our Captur has served very well... They did good deal where our dealer take our Twingo´s back and it replaced by brand-new Clio IV. Of course we had to pay some money, but conclusion after council was very reasonable.
    We really liked Twingo, it was refreshing little city-car who got a smile, but unfortynately we were not satisfied to quality.
    So...I wish to you happy spring. This morning here was -23 degrees frost, grrrr. Both cars, Captur and Clio started this morning well and works without problems....after 2 hours Calix-preheating, of course.
    -Pete-
    0w-40 can be used for any Ferrari or Lamborghini, best and most expensive oil available
    :thumbup:
    :) Come on man!! Twingo is like Lambo or Ferrari...the engine behind and rear wheel drives... :D
    Even if you have cheaper new cars in Germany, maintenance costs seems about similar to finnish dealers pricelists. Examp. 20 thkm maintenance to our Renault Captur 1,2 tCe costs 250 eur. Its including the pollution filter replace. Twingo´s maintenance costs are similar.
    Renault empfiehlt ja eigenes Renault ELF Öl, was auch Sinn macht und aus Laiensicht qualitativ optimal ist.
    LG
    Benni aka pLeXa
    In here, Finland, our accredited Renault-dealer uses Mobil New Life 0W-40 oil.
    Same oil to all newest Renault petrol motors, turbos or without turbos. This has not caused any problems. Sometimes we may have in midwinter mornings even -35 degrees frost. 0W-class oils are necessary.
    I have read some car magazine test drive article which told that Twingo´s front seats are developed by Mercedes. :) They are closely related MB A-class seats.
    However, rust is under warranty, appeared anywhere. When rust handled seats, its even safety issue.
    Vielen dank! Are you ignored, that the Twingo´s battery charging system is controlled by "smart technology". This mean,that battery is not charged continously, only if necessary and drive conditions may be affected charging. Charging is intented to concentrate engine braking etc. This causes, that charging voltage varies sometimes.This is shown to be user lights between brightering, heater fan enlarge revs etc.... This is normal many present cars. This is a result of emission reductions.
    I have had many cars like this system, don´t be worry.
    Please report the result.
    Of course, i will report! Switch ordered today but i think replace will go after christmas, even after new year. My dealer ring to me, when switch arrives. After that we agreed time to fix. It is reportedly quick to change. Then i will run sometime, so i can see if it helps.
    And Marco, don´t worry. I was poor english when i was school, and nowadays too, but as you see, we understand in here well together. Keep it simple and its easy! When you print german language, i try get clear used to help google-translator. This is your forum and german is this forum main language. In here Finland, Twingo3 enthusiast do not have much, and its great to be in here and share experiences!!
    Hi
    I have had the Same Problem in the past, but only one time.
    After stopping and starting the car manually with the key it works normally.
    I ask my dealer for that, but he can not find any problem.
    Okay. You have completely same problem and your dealer opinion was, nothing wrong...
    My dealer tells, that Renault and Dacia´s light/signal switch problem is well-known issue, and he tells too, that can causes a wide range of strange phenomenas.
    Turn signal probs, low beam probs, high beam probs etc.
    He also suspect, that the Twingo does not a old style light-relays. Light/signal switch guides directly control box, or something. Broken light/turn-switch or some kind malfunction in there can messed that box and control gets stuck.
    I dont know, is that true, but about that kind he says.
    We have in here northern dark winter-season, dark at 15.30 pm to -9.00 a.m. Light problems are very bothersomes.
    When new switch has been installed, i tell you if it helps.
    Our car has been strange head-light malfunction few times when we drived it in the dark. First i did think, that was some transient problem, but not it isn´t.
    When main light switched on (our Twingo´s main light works manually), sometimes low beams bog down and high beams not working! This happened specially after that, if you use signal turn right. Even light on/park/off rotary switch muted...This failure goes away, if you stop the car and shut down main power and start car again. Then everything works again normal.
    Today i did call our local dealer/repair and new light/signal turn switch was ordered from the factory.
    He says, that is known problem Renault/Dacia cars.
    - YouTube
    Welcome by this Forum Petsku !! do´nt worry my english is very bad but i know what do you mean !!
    Thanks, or danke!! :) I did explore your forum and i noticed, that In Gemany you have large palet of models and great equipments. In here we can only dream Twingo with tce turbo motor or EDC dual-clutch!! Or R-link!! Finnish Renault dealers Twingo´s price list including only basic models with 5-speed manual gearbox, sce motor and R&GO audio. When my wife sign order papers last spring, luckily, panoramic roof was in short special campaign and dealer haves car in stock. Usually it costs about 1500 euros extra and means that order time stretches very long. This is normal in Finland. Every special things to your new car and everything derogating what you want, you must wait long and its cost lots and lots of extra. X( Even decoration stickers costs like they would be make gold. Few extra-equipment, and Twingo is more expensive than bigger Clio-tce. Its no wonder, why a-segment not sell in Finland.
    I think, Twingos EDC is same 6-speed Getracs "powershift" than we have in our Captur?? If it is, that means lot of fun with 0,9 tce turbo! Hey folks, i am jealous to you!
    bleiben Sie dran zu!! :D
    Pete
    Hello! And winter-greetings from Finland! I living small town called Saarijärvi in middle of Finland! I looking your forum with google-translator (yes, i don´t speak any word of Germany!) and your discussion, how swap to speed-limiter -> cruise control wake up me!! You have great forum and lot of good things and ideas driving T3.
    In here Finland, Twingo 3 is very rare and low selling car model. Actually whole a-segment is low selling car-size in here.
    My wife bought her brand new Twingo 5/16. Its 1.0 Sce 71 S&S soleil limited. Soleil means here Finland, that Twingo is equipped fabric panorama roof.
    We like our Twingo very much (we have other Renault too, Captur 1,2 tce EDC) but starting owner with our Twingo haves unfortynately bad lucky. Oil warning lamp did start blink when car was driving about 3000 km, and that causes finally, that whole motor replaced bran new. Our local dealer did this repair and of course Renault-quarantee buys costs and spare-car bills. In here we have 4 years quarantee for Renaults.
    But althouhg were like this car and this works winter conditions too. Last week we have almost -20 celsius frost...PTC-heater helps warming and seat warmers are very powerfull. ESP takes control even we driving slippery ice. We have winter tyres "no stud, types".
    Iam sorry, i have bad english too, but try guys to get clear!!
    Pete
