there is no prob. thank you again for the time spending.
Beiträge von Argy22
Hello to all,
Alles anzeigenFirst of all ... if the wrench is lit you should contact your dealer for clarificationIf you are able to reset the wrench and it comes back on later, I suggest to contact your dealer for clarification.
Did you try to read the failure?
If so, you will receive a code, which can be detailed by google-search, to find out the reason.Well, after googling "TPMS" ... usually the T3 has no active tire pressure measurement system. It is done using the ABS sensors.
You have to program the "pressure" to the ECU, by selecting the tire symbol in your display using the buttons on your wiper stick. If the symbol is visible, press and hold one of the buttons. The display will change and inform you about the programming. BTW. the programming works only, if your car is in motion, assuming that your tire pressure is ok! That should solve the problem.
If the wrench still comes back on, you might have a failure with one of the ABS sensors ... in this case ... you should contact your dealer for clarification.i thought early t3 models had direct tpms. I bought it second hand for my wife. 2016 model. i have done the wiper stick thing many times. For a while tyre pressure symbol and wrench are gone but after a few kilometers (especially in the highway) both lights always come on. How can i read the failure through ddt4all? Can you indicate the submenu? Thanks for your help.
Hello to all,
I recently bought a twingo 3 - 2016 first registration. TPMS warning light (& wrench) are always on no matter if i reset the tpms feature or not. After a while lights up again. So i think is a missing tpms valve (direct tpms) or a battery thing. I need to turn off the feature. When im trying to do it from ddt4all through cluster / tdb menu the lights go off upon software reset but i get an "errorP" indication into the dashboard. The vehicle starts just fine. When i turn the feature on again all fine in the dashboard. Has anyone experience on this case. Maybe i do something wrong? Kindly advice.
PS. Tpms feature is not necessary in my country's TUV inspection.
Thank you.
