Ok, thanks, good to know. I give up, will just make an appointment with my chip tuner.
Beiträge von Janjaapjuh
... that should also work at home ... : thumbup:
Which software were you using?
I've tried PyRen but VP037 is not listed under injection -> VIN Programming.
A little update for future readers. Short after last post i've brought my Twingo to the dealer. The error codes indicated a defective turbo (wastegate), but all it needed was a command for the turbo to be "taught-in". Apparently, the chiptuning overwrote this data. It's now running like a dream; much smoother power curve and thus no unwanted harsh acceleration, also with cold engine.
I have a 2015 Twingo 3 0.9 tce 90HP chiptuned to 110HP. Lately the car accelerates very bad and inconsistent. The turbo builds pressure very harsh early in the revs while higher it flattens out. The turbo blow off whistle is cool, but I have the idea it loses pressure too soon. As it turns out there are some codes stored in the car:
DF101, DF1017, DF1554, DF1188(actuator blocked in open position). I believe something is wrong with the turbo inlet valve. Does this necessarily mean the whole turbo needs to be replaced? Maybe other people have had this problem in the past and have suggestions?
Thanks
Ich möchte die Höchstgeschwindigkeit anpassen. Mein 0,9 tce fährt jetzt nicht schneller als 160 km/h durch einen Limiter. Weiß jemand wo ich den Limiter in ddt4all finden / ändern kann?
EDIT: Chiptuned 110PS
