Yes!!!!
KW Gewindefahrwerk Twingo GT
SPARSPARSPARSPARSPAR:P
Hi @termaltake,Property i have now exactly measured, because my dealer still have a GT standing.At the front it is 4.5 cm and at the back 3.5 cm lower now
Thank you very much for taking the measurements, partner
I really appreciate the inconvenience you've taken
Hey @termaltake very welcome my friend from the island
friend to gt
the item: forgemotorsport.co.uk/Nissan_R…pacer--product--1559.html
this item its OK to twingo gt MK3 GT
comming soon vídeo y MP3: P
the sound itssss .....
the sound tis very hard
its fantastics
Please think about loosing warranty if you build in this valve. I am also not sure if it's good for the lifetime of the turbo charger. I heard a lot of different discussions about this kind of valve.
Nevertheless, i would appreciate to hear a sound file of a tce90 with this type of valve.
But back to topic... -
Quiet gets on and takes off in 15 minutes
My mechanic says that it simply makes noise it is neither bad nor good it only makes noise and with heat it can go something softer because it only uses air from the outside cold and clean
What it does is that the air that should serially send it to the filter, called recirculation of the surplus pressure of the turbo, osea hot air, now picks it up and expels it to the outside, the car I think goes a little softer but very little It seems to me
But go noise more handsome
I have to record a video that is heard well because the microphone of the cell is saturated with the blow
Externer Inhalt www.youtube.comInhalte von externen Seiten werden ohne Ihre Zustimmung nicht automatisch geladen und angezeigt.Durch die Aktivierung der externen Inhalte erklären Sie sich damit einverstanden, dass personenbezogene Daten an Drittplattformen übermittelt werden. Mehr Informationen dazu haben wir in unserer Datenschutzerklärung zur Verfügung gestellt. -
Falls jemand genug Geld übrig hat, sind die grad im Angebot:
http://www.sportfahrwerk-billiger.de/index.html -
Aber keine für den Twingo III. Zuminderst kann ich keine für den Twingo da finden !
