Schaut echt genial aus!!!
KW Gewindefahrwerk Twingo GT
Kurven schon getestet @renneringelb, ganz was anderes,einfach perfekt
Jo echt heisses
Teil
Und die Schlappen passen genau rein
VA 205/40 HA 225/35 -
Companion many congratulations the car to be left under low and fat fat
Hehehehe
By chance you have measured how much lower than standard?
Or could you take some measures? From the wheel pass for example or not from where you can, if I compare it with mine that goes as standard and I get a better idea
I would greatly appreciate it
Hello @termaltake, thank you first, I am absolutely satisfied with the installation of KW suspension. Sure no problem. So the distance from the center of the rim to the mud guard is exactly 320mm, rear and front. And the entire height of the GT is now instead of 1544, ca.1490mm. The distance from the ground to the deepest part (exhaust pipe) is now only 140mm. Here in Austria is 110mm the maximum limit down (unloaded). So I would still have 30mm clearance, but I will leave it as it is now.
perfect friend :D10000 of thanks
I wait the kit of spring to elia fo gt, say me that low 30mm .. in julio in buy say me
i can´t pay the kw or bilsten ps4
only spring
only spring
Ok, yes the suspension is not cheap but also not expensive, if one follows the road situation before. I would save on the suspension, springs are just for the look, suspension for the performace, my tip. The GT runs like on rails around the curves.
@termaltake
Is clearly not the same car yet it is awesome now, and later with more power crazy hehe
